Hi!
I have problems with all autocad products.
I installed with sucess Autocad for mac 2013 (for exemple... cause I tryed also with 2011-2012 versions)
But when I try to start the program, it crash. Each time.
And even with trial products!!!
I look up with my MAC (OS X 10.6.8 version) and Apple. I have done many check up, update, smart, etc...
Everything is okay with my computer... so probably a missing file issue with CAD... I really don't know....
Anyone got the same problem???
Thank you.
Cynthia
Console info:
13-01-24 16:33:40 [0x0-0x52052].com.autodesk.AutoCAD[761] set SkipExisting to true
13-01-24 16:33:40 [0x0-0x52052].com.autodesk.AutoCAD[761] Materials Configuration Not Found in the Bundle - Skipping
Hi Cynthia,
Have you passed an Activation? - dialog box, that at first run asks about activation of AutoCAD.
If no, and you have some of Adobe products on your Mac (such as Photoshop or Illustrator), then you can try this:
http://macacad.wordpress.com/2010/11/25/autocad-for-mac-and-adobe-software/
Maxim
Hi! I finally found the file (Publisher flex net) and I followed the steps written in your blog, but still not working.
Here you have the consol info after I tried to launch CAD last time:
13-01-28 17:17:46 [0x0-0x1e01e].com.autodesk.AutoCAD[560] Autoload Feature Installed
13-01-28 17:17:46 [0x0-0x1e01e].com.autodesk.AutoCAD[560] Materials Configuration Not Found in the Bundle - Skipping
