After AC 2014 LT MAC crash I can no longer highlight lines, objects, etc then press keys, such as RO for rotate, M for move, Command G for group, the Delete key to delete.
Now I must first press the C key for copy, the highlight the hit the return key, then hit Control V to paste. This is reverse of the methods prior to the crash.
If I want to Rotate, 1st press RO, then highlight, the return, the grab and rotate.
If I want to Move, 1st press MO, the highlight, then ....... where prior I would highlight, Press M & move with cursor.
Prior to crash I was in the process of using Match Pooperties, AC crashed.
I have not installed any new programs, updates or hardware to this system.
Solved by maxim_k. Go to Solution.
