AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Adding text to a dimension
2 REPLIES 2
1554 Views, 2 Replies
I'm using AC LT 2014 on Macbook Pro with Mavericks.
I'm trying to add additional text to an existing dimension line.  I go to the text override box in Properties and type '<> verify in field' followed by enter.  The change takes place in the drawing area but it is so small you can't read it.  I can't figure out how to maintain the text size of the original dimension.
2 REPLIES 2
maxim_k
You control the size of dimension text via Dimension Style settings (for
all dimensions of the same Dim Style in the drawing). Go to menu Format->
Dimension style, in dialog select style you are using, select Edit from
"gear" menu above Dim style list, go tobText tab, change text height (this
height will work if the height of Text Style you are using for this Dim
style is 0 - zero). In the drawing the text height will be actually
multiple of DIMSCALE variable and value of text height you just set - this
is true for non-annoy active Dim style.
You can also modify text height for individual dimension in the drawing -
select dimension, go to Properties palette, select All tab, scroll down to
Text section and change text height.
Maxim
Maxim
Sent from my iPhone
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
in reply to: maxim_k
Thank you for the quick reply.  I had already defined both a Dimension Style along with a corresponding Text Style.  It turns out the the text style I had defined was not set to 0.
”Boost
