Hi All,
Had to re-add custom hatches after having to "Reset Application Options". The patterns are in the right location, but for some reason are not loading when I try to attach a hatch to an object. Anyone know why this might be happening?
Trang
Solved by maxim_k. Go to Solution.
I typed in the hatch command; clicked on open library; clicked on the "Show All" and moved the cursor to add hatch then I added the patterns, but when it was done no new hatch patterns appeared in the "Show All" or the "Customs" section. I then went to "Find in Finder" and all the files I had added are in that location. Here is the path that they are in User/Library/Application Support/Autodesk/roaming/AutoCAD 2013/R19.0/enu/Support.
Trang
All of these hatches worked for both Mountain Lion and Maverick before. Could there be a glitch with Maverick when you do an Application Reset? I tried restarting the computer and AutoCAD with no luck. Even creating a folder as you suggested didn't work. I did notice today that when I opened the "find in finder" that some of the hatches are showing up with a different icon and it reads as Alias (see attached image), but before they were imported they read as Adobe Photoshop Patterns file - it still doesn't explain why the others aren't showing up which all came from the same download hatch package that worked before.
Trang
Hi Trang,
Just now I launched Mavericks with AC 2013, reset Application preferences. Now I add patterns which are in a folder on my Desktop:
via Hatch Library window, an here is a result:
And here they are (as aliases) inside ~/Library/Application Support/Autodesk/roaming/AutoCAD 2013/R19.0/enu/Support folder:
Everything works fine, strange that you have issues with this...
Maxim
Hi Maxim,
Before I reset, I didn't have an issue with loading them either. One thing I noticed is that when I tried to load one or a bunch of hatches, the rainbow wheel that indicates that it is loading doesn't show up anymore. Here is what I see below.
Trang
Look:
I just deleted source .PAT files from my Desktop and get the same results as you - empty Custom section in Hatch Library.
That's whi I always use another way for adding Hatches to AutoCAD - special folder + adding it to Support Files Search Path.
Maxim
It says the original can't be found and when I tried to fix the alias it had an error message (see images)
Trang
I had always stored a set of .pats on our network server and added them through the hatch command "Add Hatch", which then got transfered to my computer...didn't have an issue with this method before. Adding the path through the preference command is the first time I went through that route - I do find it takes a long time to load the hatches?
Trang
Adding a path to a folder of downloaded hatch patterns via prferences just makes AutoCAD crash and freeze. I've never been able to add downloaded hatch patterns to AutoCAD for Mac, I don't think the platform supports it.
