trying to flatten file .. all lines connected to different layers in 3d. when viewed from top 3d view things are regular. except measurements. Will send file. ive tired flatshot. did not seem to do anything.
Solved by maxim_k. Go to Solution.
FLATSHOT only works with solids - it won't help you with your lines. The FLATTEN command would be helpful here, but is not available on AutoCAD for MAC 2011.
I do not know of a way to automatically fix this without the FLATTEN command, but you can fix your lines manually. The easiest way to do this is to use select a group of similar objects. Make sure your UCS is "world." In the properties inspector, see the geometry section. For Lines, change the Start Z & End Z to 0. For Polylines and other closed objects, change the elevation to 0. You may need to convert your splines to polylines using SPLINEDIT before changing their elevation. Good luck.
I have no way to test this and have never tried it but you can try this tip from Kate Morrical's LT Unlimited blog Mimic Express Tool “Flatten” which can be found at the following link.
http://ltunlimited.typepad.com/my_weblog/2010/07/mimic-express-tool-flatten.html
@Johneng wrote:I have no way to test this and have never tried it but you can try this tip from Kate Morrical's LT Unlimited blog Mimic Express Tool “Flatten” which can be found at the following link.
Hi all,
Yes this is the Great tip from Kate!
It flatten everything (including splines)!
You can try small Lisp routine, based on Kate's script, that I wrote. I have tried it on your drawing file, and it works.
Just appload Flatten_all.lsp, and call FLAT command, select objects you need to be flatten and hit Enter.
Maxim
sounds great. i downloaded the flatten _all .lsp file however i not sure what to do with it now. sorry to sound like a pain.
here is another file that is doing the same thing. i still cannot get it to work for autocad for mac. but i went to a friends old autocad 2008 and used flatten command.
seemed to easy not to be on the mac lt version... but still could not get this file to flatten. it might be because of the objects that are in the drawing not sure. but if your willing to give a look ill surely appreciate it.
Thanks again
Hi jjdd285,
Unzip downloaded file to some place in your home folder (I use specially created folder "LSP" for my custom Lisp routines).
Open your file, from Tools menu select "Load Application...", in Load application dialog navigate to your LISP file, select it and pick "Load" button. Close dialog, type FLAT at Command prompt.... you will see result.
You can also check-mark "Add to history" and applications, that you already have loaded some time ago will stay in History list for fast loading.
For more help see On-line Help on Load/Unload Applications Dialog Box
Maxim
in attachment - your flatten file (just have purged unused blocks from it)
