If you use a regurlar USB mouse to do a 3D orbit, everything behaves as expected. Rotating your object is analagous to grabbing the front face, and as you move your mouse to the left, it is like you are moving the front of your object to the left, rotating it clockwise. Similarly, moving your mouse up rotates the front of your object up.
The problem arises when you use the trackpad to orbit. Sliding your figers up rotates the object up, as expect, but slide to the left, and the front face of your object rotates to the right!
This must be a bug, right? Is anyone else observing this same issue? According to this post, the problem is also present on a magic mouse. It was there on the 2013 version, and I just downloaded the trial of the 2014 version, and the issue is there too. Panning is fine, its just on orbit. Chaning Mac trackpad preferences for scrolling has no effect.
Shift + 2 finger drag on the trackpad, shift + 3rd Button on a mouse. I thought it was the same thing as 3D orbit, but if I type the command and click and 1 finger drag, it behaves correctly. Seems to just be 2 finger "scrolling" related.
Does nobody else have this issue? Is everyone using a mouse? I thought the shift+scroll method of turning your object was fairly standard procedure.
