Hi, I am trying to import this dwg file which is in 3D into Sketchup, but only 2 parts of the model import with solid faces.
What do I need to do in AutoCAD so that all the lines with faces import correctly, can anyone help.
I have attached the CAD file in question.
Many thanks,
Nat
Solved by maxim_k. Go to Solution.
Welcome to the Autodesk Forums!
Hi Nat,
Please look here:
http://forums.autodesk.com/t5/AutoCAD-for-Mac/surface-extrusion-cap/m-p/4399067#M9061
Please try convert 3D Solids objects to 3D faces first, then try to import in Sketchup. I also noticed that four legs of the table are 3d Solids inside block, which is inside another block that compose all 4 legs - you have to explode them too.
Maxim
