AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
2013 LT printers
7 REPLIES 7
Message 1 of 8
709 Views, 7 Replies
2013 LT printers
I am trying this package and am having problems with printers. The package only sees the system printers consequently I am unable to make plots larger than the paper sizes they support (Tabloid). The windows version I have used (2011 LT) had drivers for DWG to PDF, DWG to DWF etc. which allowed me to select large sheet sizes in the layouts. I know that I can print to PDf using the Mac system but the largest paper size is limited to the installed system printers limitations.
Macbook Pro running Lion.
Am I missing something ?
I also posted this on the Autocad LT forum.
7 REPLIES 7
Message 2 of 8
maxim_k
In Edit page setup dialog (you can call it from Layout or Model) open Paper Size drop-down list, at the bottom of the list select "Manage custom sizes", click on "+" and select New or Select from list:
Edit the name of paper size (if you need), non-printable area, etc.
Click OK, your new paper will show in paper sizes list.
HTH
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 8
in reply to: maxim_k
Thanks that will work.
I must admit I was hoping someone would just say go "here" for the missing printer drivers and have it all done for me, guess I need to open up my windows version and copy down all the sheet sizes and printable area settings.
Message 4 of 8
mzarchs
I have the same problem and worked around to the same solution.  However, the preview of the PDF is always upside down.  Does anyone have any suggestion?
Message 5 of 8
in reply to: mzarchs
I don't have  a work around for the upside down pdf, but I am curious about your results with pdf.
Besides being upside down, is the  quality good?  Have you experienced any random cropping?
Message 6 of 8
mzarchs
This only my second day on LT 2013 for Mac so I haven't a long history.  So far the PDFs seem complete once the orientation of the page is correctly established.
Message 7 of 8
maxim_k
Have you tried to play with this option in Page Setup dialog:
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 8 of 8
mzarchs
Thanks.  I didn't see that the Page Setup Manager has a second half to the right that could be expanded.  Why hide it to begin with?  Thanks again.
”Boost
