Is there a way to get my menus and stuff I set up in 2012 into 2013?
I know two ways:
1. Run CUI command and customize everything from scratch
2. Manually edit .CUI files
Maxim
All CUI files, that are affected during customization via CUI command, are in "~/Library/Application Support/Autodesk/roaming/AutoCAD 2012/R18.2/enu/Support/" folder:
- MenuGroup.cui - contains all menu macros (default and custom)
- PopMenuRoot.cui - contains menu structure
- Workflow.cui - ToolSets palette structure
- Workspace.cui - exists for compatibility (as I think)
Maxim
Is it possible to transfer these cui-files from one mac to another?
Wim
Yes, just copy files I mentioned in previous post to the same location on another Mac (backup existing files just in case)
Maxim
