AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
2-finger zoom instead of pan
5 REPLIES 5
1627 Views, 5 Replies
I have Autocad for Mac 2011 and when I try to use 2-finger dragging to pan, it zooms. It also zooms with pinch gestures.
I can only pan using option+2-finger dragging or space+1-finger dragging. Does anyone knows how I can enable panning witn 2-finger dragging, without having to press option key?
Thank you,
Lucas
5 REPLIES 5
I too would really like to figure out how to do this; I used to love to be able to do this with AutoCAD for Mac, along with shift-two-finger sweep for rotate, somewhat like how it works on an iPad.
When I recently switched to Windows however, I found that the lack of maneuverability was driving me up the wall, and decided that it was a major feature I wasn't willing to lose, and so I switched back to Mac.
I hope I magically find something out there beyond the closest I have gotten which is typing the command 'cui' in AutoCAD, allowing you to see all of the commands and some keybinds, but nothing to do with the trackpad.
Cheers
maxim_k
In AutoCAD for Mac you can use standard Trackpad gestures:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15833633&linkID=15839490
You can not reconfigure them.
Do you have some troubles with this gestures?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
in reply to: maxim_k
Same problem. My other mac do this. Solutions???
Did you find an answer to your querry?
Did you figure this out? Is the 2 finger drag to pan working now?
”Boost
