I have Autocad for Mac 2011 and when I try to use 2-finger dragging to pan, it zooms. It also zooms with pinch gestures.
I can only pan using option+2-finger dragging or space+1-finger dragging. Does anyone knows how I can enable panning witn 2-finger dragging, without having to press option key?
Thank you,
Lucas
I too would really like to figure out how to do this; I used to love to be able to do this with AutoCAD for Mac, along with shift-two-finger sweep for rotate, somewhat like how it works on an iPad.
When I recently switched to Windows however, I found that the lack of maneuverability was driving me up the wall, and decided that it was a major feature I wasn't willing to lose, and so I switched back to Mac.
I hope I magically find something out there beyond the closest I have gotten which is typing the command 'cui' in AutoCAD, allowing you to see all of the commands and some keybinds, but nothing to do with the trackpad.
Cheers
In AutoCAD for Mac you can use standard Trackpad gestures:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15833633&linkID=15839490
You can not reconfigure them.
Do you have some troubles with this gestures?
Maxim
