Hi
When using AutoCAD Mac on my Macbook Pro (2012 mid) sometimes my trackpad gesture of 2 finger panning switches to zoom. There doesn't seem to be anything obvious which is causing it, but it seems to happen when changing from different windows in AutoCAD. I can't find a fix other than restarting the program multiple times. I know that you cannot change the trackpad multi-touch gestures.
If anyone knows what causes this and how to fix it, that would be brilliant!
Solved by maxim_k. Go to Solution.
Yes, I do know that if you pinch with two fingers on the trackpad it zooms in and out. But this is not the case which is causing the issue as I am most definitely not pinching my fingers when using the trackpad (I tested the difference in the zooms when this issue was occuring, and they zoom at a different rate). I still require AutoCAD to regonise the pinch gesture on the trackpad as well, so turning off the "Zoom in or out / Pinch with two fingers" gesture in Scroll & Zoom of Preferences can't be the answer unfortunately. Unless toggling this setting on and off fixes the problem?
Thanks for you fast reply.
Let me try to explain the problem (i don't speak english very well):
When I drag two fingers zooom in/out happens.
If I press "alt" key with same action; then pan happens.
Is exactly the opposite than in your comment.
Any sugestion?
Thank you for yor time!
Thanks maxim_k; yes, I'm on Yosemite since today.
It was really strange, because Autocad was working fine and suddenly the "pan" stops working. I guess we have to wait for the update.
Thanks for your very quick answer.
i have the same problem and i don't have Yosemite also i tried restarting and still no solution any suggestions ?
@maxim_k wrote:
Welcome to Autodesk Forums!
Are you on Yosemite?
There is a defect in Yosemite which changes Trackpad behavior with zoom and pan in AutoCAD for Mac to opposite than it was before:
http://forums.autodesk.com/t5/autocad-for-mac-general/auto-cad-running-yosemite/td-p/5345757
Maxim
REPOST FROM ANOTHER DISCUSSION
I'm also having this problem after updating to Yosemite.
I assume no one's been able to fix it yet but you can also
AutoCad> Preferences> General and check the box that says something like "space bar hold to pan" or something like that.
It's easier than using the alt key since you can hold space bar and pan with just one finger. That way you only have yo use one hand instead of both.
I do hope this issue gets fixed soon though.
I find the pinch really un-user friendly! I used to be able to zoom but just using 2 fingers on the trackpad but all of a sudden I have to use the ALT and 2 fingers!! How do I change it so I dont have to use alt?
I use to just pan by holding down the space bar and moving my finger on the trackpad!!
OK, now it's 2020 and I'm having the same problem on AutoCAD LT 2020 for Mac, with Catalina. It's happened twice in the last month. Last time it suddenly happened then eventually fixed itself; but's happening right now and I can't find an answer. BTW, the two-finger pan is still working easily in other programs, but the Autocad is just not doing it.
I'm having the same issue with AutoCAD 2021 & Mac Big Sur on the new M1. Anyone figure out a fix?
I am also having this problem with increasing frequency AutoCAD for Mac 2022-Big Sur-M1- Closing the program and restarting helped for awhile but now it can start out panning with the 2 finger movement and then switch to zooming. Frustrating!
