AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Recover sv$ (autosave) files
12 REPLIES 12
Message 1 of 13
dmccad
92636 Views, 12 Replies
How can I find the "tmp" folder where autocad allocates the autosave files so that I can recover one after a sudden crash?
I just can't find the folder in finder!
Thanx
12 REPLIES 12
Message 2 of 13
maxim_k
in reply to: dmccad
you can find "autosaved" files in "/private/tmp/", because tmp is just an alias (link) to this folder. Also note, that private folder is "hidden folder", so you have to enable Finder to show hidden files.
I think, that  it will be interesting for you to read this: Changing the Autosave File Location in AutoCAD for Mac
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 13
dmccad
in reply to: maxim_k
yeah, that helped. I changed the location of the temp files so I can access them easier...the problem now is that autocad crashes quite a lot... 😞
Message 4 of 13
I read the article you suggest, and was able to change the folder where my autosave files are saved, but i still can't find the tmp folder where my lost work may be... I enabled finder to show the hidden folders, but it wasn't enough...
HEEEELP PLEASE!
Message 5 of 13
in reply to: dmccad
In the windows explorer bar type %TEMP% and it will bring you to your temp folder. You will need to have hidden folders and files showing in Tools-> Options.
~ Rhea
Message 6 of 13
maxim_k
~ Rhea
Sorry, but here is Mac world - no Explorer, no Tools->Options...
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 7 of 13
Well I came across this when I was looking up .sv$ files and im on Windows so it may help a non mac user in the future.
Message 8 of 13
Is there anyway to recover the sv$ file if I never changed the autosave loaction from the default and I stupidly already restarted my computer? I just read somewhere that the temporary folder where AutoCAD dumps the sv$ automatically empties when the computer is restarted,
I've lost so much work because I didn't save my progress as I went like I should have... I'm sure the sv$ would be there waiting for me somewhere if I hadn't already rebooted.
Please tell me there is some way to get it back!
Message 9 of 13
maxim_k
If you are using AutoCAD 2012 or 2013 for Mac, then look for your sv$ files in "~/Documents/Autodesk/Autosave/" folder (Documents folder inside your home folder)
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 10 of 13
Hello all,
I've saved by mistake an older version of my project file over the new one - three weeks of work gone in a second..
i've trued looking for the .sv$ files in the autosave file, in the ~tmp folder (after enabeling hidden files) but without any succes i could only find the .sv$ of the files which are open
I need help here!!!
thanks
Hagay
Message 11 of 13
maxim_k
@Anonymous wrote:
i've trued looking for the .sv$ files in the autosave file, in the ~tmp folder (after enabeling hidden files) but without any succes..
Hagay
If you are using AC 2011, and there are no auto-saved files in "/private/tmp/" folder, then you loose them forever, because the contents of "/private/tmp/" folder erased on each system reboot.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 12 of 13
I have not logged out and I am on a university computer so i cannot show hidden files? how can i recover the file i was working on if i have saved before but not recently. when i open the file it does not recover it just goes to the old file. PC and 2014 edition
Message 13 of 13
maxim_k
in reply to: dmccad
Welcome to Autodesk Forums!
Although it is AC for Mac forum let me try:
What do you see in Recover manager?
When you are trying to open your damaged file - does AutoCAD asks about Recover?
Or you just not saved file before closing it?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
”Boost
