AutoCAD Forum
vuie asd drawings in trueview
1 REPLY 1
gscob01
371 Views, 1 Reply
Hi iv just upgraded to building design suite from just autocad. We used to use trueview to take any extra dims required throughout manufactur, very useful tool however since using ASD we can open and look at the working drawings (layout tabs) but cant take dims they all come out to the scale witch doesn't help much (eg 10mm plate comes up at 1mm times by the scale 1:8 comes out at 8mm). any thoughts on how to overcome this many thanks
chippy-g
1 REPLY 1
pendean
in reply to: gscob01
Wow! Did you end up posting in the completely wrong forum: do you never want an answer?
ASD forum is here: http://forums.autodesk.com/t5/AutoCAD-Structural-Detailing/bd-p/346
TrueView forum is here: http://forums.autodesk.com/t5/DWG-TrueView/bd-p/109
Good luck: it might help everyone if you posted a sample DWG that exhibits the problem.
”Boost
