AutoCAD Forum
Unknown command "image" - troubleshooting.
4 REPLIES 4
472 Views, 4 Replies
Hi. I'm actually using an older version of AutoCAD - r14 - but it looks like other people have had similar issues in newer versions, but I haven't seen an answer so I'll try posting here.
I've used raster images with this version many times in the past. However, I just tried inserting one and I get the message Unknown command "IMAGE." I've tried restarting AutoCAD, restarting my computer, and using the command in different files, with the same results.
Any help would be appreciated.
Thanks.
4 REPLIES 4
pendean
In R14, go to the INSERT pulldown menu and select RASTER IMAGE: what happens? If the same, then something changed with your old R14 setup.
in reply to: pendean
Yes, that's when it happens. I go to Insert>Raster Image. Nothing pops up, no dialog or anything, and in the command line it just says "Unknown command IMAGE." I'm assuming it's a problem with some sort of setting somewhere, I just don't know what it would be, or what I might have done to cause the change.
pendean
Did you load or change your primary MNS/MNR menu file?
or do some editing?
There is no setting to change, you lost the command for a reason, often by loading or unloading a major element in AutoCAD.
Not that I am aware of. Not intentionally at least.
We do have it installed on another workstation, and the function works on that particular installation. Would it be possible to copy some files from the operational workstation onto the one without the insert raster command?
”Boost
