Hi. I'm actually using an older version of AutoCAD - r14 - but it looks like other people have had similar issues in newer versions, but I haven't seen an answer so I'll try posting here.
I've used raster images with this version many times in the past. However, I just tried inserting one and I get the message Unknown command "IMAGE." I've tried restarting AutoCAD, restarting my computer, and using the command in different files, with the same results.
Any help would be appreciated.
Thanks.
Yes, that's when it happens. I go to Insert>Raster Image. Nothing pops up, no dialog or anything, and in the command line it just says "Unknown command IMAGE." I'm assuming it's a problem with some sort of setting somewhere, I just don't know what it would be, or what I might have done to cause the change.
Not that I am aware of. Not intentionally at least.
We do have it installed on another workstation, and the function works on that particular installation. Would it be possible to copy some files from the operational workstation onto the one without the insert raster command?
