AutoCAD Express Tools
Active Contributor
sbcadguy
Message 11 of 11 (84 Views)
Re: TEDIT in 2015 not working
06-16-2014 01:42 PM in reply to: pendean
Correct, it has not been part of express tools for some time.  On a fresh install, tedit is an alias to start the textedit command (defined this way in the pgp file).  I removed that alias as a test to see if the tedit lisp would work and it didn't.  Neither the original or the revised one that you posted is working.  I guess something with 2015 finally broke this old express tool command.  I guess I will have to change my workflow until someone decides to fix the lsp file.  It was just really conveniant to be able to select multiple diffrent annotation objects and batch edit them in the order they were selected.
