AutoCAD Express Tools
Valued Contributor
Bishop
Message 1 of 5 (911 Views)
Superhatch is inconsistant
911 Views, 4 Replies
06-25-2001 02:47 AM
We have 1 machine in the office that when using superhatch it will not "hatch" the entire area as one hatch, it breaks it into separate image based pieces. The rest of the office, it hatches as one entity so it can be changed easily. Even if we use the group command, it will not group them. Any ideas?
New Member
fatal
Message 2 of 5 (911 Views)
Re: Superhatch is inconsistant
08-30-2004 09:04 PM in reply to: Bishop
Did you ever figure this problem out? I've just encountered the same thing. Working fine one minute, splitting up the hatches the next?
Thanks!
New Member
ANG3L1C1TY
Message 3 of 5 (845 Views)
03-29-2012 05:34 PM in reply to: Bishop
Still no solutions for this? i prefer my hatch to be separate, but now its grouped together. is there a setting to toggle between grouped and selectable for superhatch?
Member
danseguin
Message 4 of 5 (46 Views)
07-17-2014 12:43 PM in reply to: Bishop
I'm having this problem again and never found a solution..  It happened to me a few years ago on 2012 AC (started separating the superhatches), then it was ok after I installed the 2013, now this week it's happening again on 2014 AC.
Hopefully a solution is found eventually on a variable to switch between both scenarioes, on demand...
pendean
Message 5 of 5 (41 Views)
07-17-2014 02:12 PM in reply to: danseguin
SUPERHATCH has it's flaws and nothing has changed about it yet through 2015.
Post a DWG file if you want others to try in your own file to see if they can spot the issue.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
