AutoCAD Express Tools
Valued Contributor pdn
Valued Contributor
1 Kudo
Post 1 of 5
some expresstools commands not working
2710 Views, 4 Replies
07-11-2012 07:01 AM
Hi
I installed express tools with ACADE abd ACAD, some of them don't work, example:
_.sysvdlg Unknown command "SYSVDLG".  Press F1 for help.
other commands missing:
arctextx, txt2mtxt,mocoro,dimex,dimin,qlattach
any idea
Thx in advance
Patrick
1,605 Kudos
Post 2 of 5
Re: some expresstools commands not working
07-12-2012 12:44 PM in reply to: pdn
Is DEMANDLOAD set to 3? required.
At the command line, type EXPRESSTOOLS: if it fails, ET was not installed. If it works, it will load your ETs. Follow it with EXPRESSMENU command.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Valued Contributor
1 Kudo
Post 3 of 5
07-13-2012 12:00 AM in reply to: pdn
Hello Dean
Tried that already, worked perfectly but nothing changed, still some commands missing
(although always the same) seems that it won't load certain .arx files
I can load the file manually (for example sysvdlg.arx) and then the command will work
don't understand why "most" of the commands are loaded and some are not, have been searching where in the ACAD startup the loading appears but could not find it
Regards
Patrick
New Member
0 Kudos
Post 4 of 5
10-16-2012 12:22 PM in reply to: pdn
I am experiencing the same problem. I followed all of the directions I could find to load Expresstools and I cant get the one command that I want to use to work (along with others). All I want to do is make my own linetypes. If someone could tell me how to either a) fix Expresstools or b) tell me how to do this without using Expresstools, I would appreciate it.
1,605 Kudos
Post 5 of 5
10-25-2012 06:14 AM in reply to: pdn
When you installed your AutoCAD version, did you "migrate" from an older version?
Uninstalling and reinstalling Express Tools from your program disk not an option?
