AutoCAD Express Tools
Valued Contributor
tommcgtx
Message 1 of 4 (926 Views)
Select Express tools not working
926 Views, 3 Replies
10-21-2011 09:59 AM
I have seen this posted on this forum, but there was no answer. I am using AutoCad Civil 3D 2012, with windows XP, and when I type "extrim" at the command line, I get this:
Command: extrim
"bad argument type: listp #<SUBR @2f9669b0 BONUS_ERROR>"
There are also a few other express tools that when picked from the ribbon menu, do not work either. Now, I have seen elsewhere on the web that in this case, you should make sure there are no search paths set to R14 Bonus tools (which mine aren't), or repair and update express tools from add/remove programs in the control panel. I did this, and the only thing that happened was the numbers after SUBR@ changed. Does anyone know why this is happening? Does anyone have a solution?
pendean
Message 2 of 4 (920 Views)
Re: Select Express tools not working
10-21-2011 02:12 PM in reply to: tommcgtx
reinstall Express Tools from the 2012 Disk, answer yes to replace all files and anything else it offers to replace/delete/add.
back up first.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Valued Contributor
tommcgtx
Message 3 of 4 (917 Views)
10-21-2011 02:27 PM in reply to: pendean
I don't have a disk, it was installed from an external drive by an administrator.
pendean
Message 4 of 4 (896 Views)
10-24-2011 09:29 AM in reply to: tommcgtx
Worth reinstalling to fix the problem.
