AutoCAD Express Tools
Active Member
TungNguyen85
Message 1 of 6 (136 Views)
Accepted Solution
Rotate Pickbox
136 Views, 5 Replies
07-14-2014 01:40 AM
How to rotate my pickbox when I rotated UCS
In order for you to have the type of window selection that you are looking to achieve - once you set your UCS to its new position or angle... what you want to do is make your screen align to the new UCS (or "square it up" as my CAD teacher used to explain it).
The trick to that is to simply use the PLAN command and set it to the <current> UCS.
Example after setting the UCS:
PLAN [enter] [enter]
http://autocadtips.wordpress.com/2011/12/06/2012-selectable-ucs-icon/
Even if you were to rotate your cursor by using the SNAPANG command and set it to the same angle as the USC, the selection box will still be "squared" to your screen.
http://autocadtips.wordpress.com/2014/03/27/autocad-cursorcrosshair-angle/
After you are done rotating these angles, don't forget to set them back to "normal" for the next guy.
SNAPANG = 0
UCS [enter] [enter]
~Greg
*Expert Elite*
pendean
Message 2 of 6 (125 Views)
Re: Rotate Pickbox
07-14-2014 06:46 AM in reply to: TungNguyen85
Not an Option.
Do you mean crosshairs instead by chance?
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Active Member
TungNguyen85
Message 3 of 6 (118 Views)
Re: Rotate Pickbox
07-14-2014 11:27 PM in reply to: pendean
You can see my attached. When I used command ucs, I changed OXY and rotated crosshair. But my pickbox still keep old OXY and do not rotate same crosshair. How do you rotate pickbox same crosshair
*Expert Elite*
pendean
Message 4 of 6 (104 Views)
Re: Rotate Pickbox
07-16-2014 02:38 PM in reply to: TungNguyen85
The PICKBOX never rotates: do you mean the crosshairs? They look rotates to me in your image.
greg.battin
Message 5 of 6 (85 Views)
Re: Rotate Pickbox
07-30-2014 04:49 PM in reply to: TungNguyen85
SNAPANG = 0
UCS [enter] [enter]
~Greg
Active Member
TungNguyen85
Message 6 of 6 (58 Views)
Re: Rotate Pickbox
08-08-2014 06:21 PM in reply to: greg.battin
Ok. Thanks Greg
Announcements
Need installation help?
