AutoCAD Express Tools
Active Member
Serichy76
Message 1 of 2 (892 Views)
Problem with 'Shape to Block' command in Express Tools
892 Views, 1 Replies
03-26-2012 01:26 AM
Does anyone know how to get the 'Shape to Block' command to work (under express tools).
It says select object, but no matter what object I select eg. circle, pline or line, it says invalid selection.
I am running AutoCAD 2012.  Has anyone been able to use this command?  What am I not doing? are 'shape' objects somehow different from any other objects?
I'd be gratefully for any help you can offer....
Valued Contributor
jruifer
Message 2 of 2 (884 Views)
Re: Problem with 'Shape to Block' command in Express Tools
03-26-2012 11:52 PM in reply to: Serichy76
As the command says, you can only select a shape (SHP), no other entities as circles or lines.
Post to the Community
New Post
Need installation help?
