AutoCAD Forum
Looking for an express tool similar to line break (see attached)
3 REPLIES 3
bartonrj25
829 Views, 3 Replies
I am looking for an express tool that is similar to the line break but is more like a pipe break. See attached for reference.
3 REPLIES 3
JoAnn_Hogan
in reply to: bartonrj25
Is this a 2D or 3D part??
If it is 2D you can create the break as a block and insert it in your toolpallete and insert it when you need it?
If this post solved your issue please mark as solved and Kudos are always welcome 😃
Jo - Ann
Twitter: @JoAnn_Hogan
Revit Architecture Certified Professional / Revit Structure Certified Professional / AutoCAD Certified Professional
pendean
We use a 1-unit sized block that we INSERT and size as needed (part of the INSERT command process). Nothing special needed.
bartonrj25
Thanks. That works just fine.
”Boost
