AutoCAD Forum
How to set Propulate to save in previous version of AutoCad?
1 REPLY 1
Kerryn
515 Views, 1 Reply
Hi, I use propulate on a folder of files for a complete project. I'm more than happy with the propulate command (I couldn't go back to doing the field updates the old fashioned way) the only issue I have is that the propulate always saves the file as the current version of AutoCad that I'm using, even though I have the options set to save in "AutoCad 2010". This is a problem for other users in our company who are using previous versions of AutoCad. At this stage I have to open each file, and save, so that it reverts to AutoCad 2010. Anyone have any suggestions of how I go about setting up the propulate to save in 2010, or alternatively, something I can do without having to open up every drawing file?
1 REPLY 1
pendean
in reply to: Kerryn
There is no such option if the 'template' choice doesn't do it for you.
If you have 2013 or 2014, there are freeware plug-ins in the Exchange Apps store to automate your save down needs on a bunch of files. Infact, you might be able to use the same plugin to run the commandline version of PROPULATE and SAVE down for you in one action.
”Boost
