AutoCAD Express Tools
Distinguished Contributor
wesbird
Message 1 of 2 (252 Views)
Accepted Solution
; error: no function definition: ACET-REG-MACHINE-PRODKEY
252 Views, 1 Replies
04-29-2014 10:21 AM
  I don't know since when I got this error message when I start AutoCAD:
  when I try
Command: EXPRESSTOOls
Customization file unloaded successfully. Customization Group: express
Customization file loaded successfully. Customization Group: EXPRESS
  It must be part of EXPRESSTOOls. It's really annoying. I have googled it and found not solution. How I can get rid of it?
Wes
Vault Pro 2014, Windows 7 64 bit, AutoCAD (ACA, Map) 2014
It would be helpful to know what version/flavor of AutoCAD and on what platform (OS).
Assuming Windows 7, from Control Panel, Programs and Features, you could first try using Add/Remove Features to remove Express Tools.  Be sure to re-start your machine and launch AutoCAD to verify that it is removed.  Then (if you want it) run Add/Remove again to re-install it.
If this doesn't fix things, go to the next level and run a full repair and/or re-install.
**Master
dmfrazier
Message 2 of 2 (230 Views)
Re: ; error: no function definition: ACET-REG-MACHINE-PRODKEY
05-13-2014 08:20 AM in reply to: wesbird
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
