I have a table but not not made by table command but line command. I would like to transfer the text of this hand made table content to excel. I tried "DATAEXTRACTION" but I could not manage to get anything from it. I need your help.
Thank you
PS: I attached the file.
Solved by dmfrazier. Go to Solution.
Unfortunately there is no built-in command in AutoCAD that will do what you want.
See if this search result leads you to something that works:
Or this:
http://forums.autodesk.com/t5/forums/searchpage/tab/message?filter=labels&q=text+to+table
Thank you Sir. From the links you've shared I understood that it is possible to do what I want by using list. I do not how to write or if I get a ready to work list, I do not know where to put the code in. I ve used some preprepared vba codes for excel but never i AutoCAD.
If you may forward me to someone who may help me, I will appriciate it.
Thank you.
Regards
Customization Discussion area:
http://forums.autodesk.com/t5/Visual-LISP-AutoLISP-and-General/bd-p/130
Visual Basic Customization Forum:
http://forums.autodesk.com/t5/Visual-Basic-Customization/bd-p/33
Autodesk ObjectARX Customization Forum:
http://forums.autodesk.com/t5/Autodesk-ObjectARX/bd-p/34
.NET Customization Forum:
http://forums.autodesk.com/t5/NET/bd-p/152
You're very welcome.
I understand your inexperience with AutoCAD and its programming interfaces.
Please see the attached file - hopefully this will help you get over this little "speed bump".
In the ZIP file is:
1. A copy of the DWG you posted.
2. A DWG in which the 'table" from your DWG has been converted to an AutoCAD Table object.
3. A CSV (Comma Separated Values) file made by exporting the data from the AutoCAD Table.
The CSV file can be opened in Excel. It will probably need some clean-up.
If you want to know more about how this was done (so that you might do it yourself), just ask and I will outline the process for you.
Thank you very much Sir.
I appreciate your help.
I definetely would like to do the process by myself next time, if you may give the directions.
Thank you again 🙂
Sorry for the delay in getting back to you.
If I recall correctly, you can get an AutoLISP routine named "CONVERT OLD TABLE" (COT_Convert_Old_TableV1.6a.lsp) from here:
http://www.theswamp.org/index.php?topic=35884.0
Save a copy of the LISP file in one of your support folders.
(The following is based on AutoCAD 2013.)
Launch AutoCAD and load the LISP routine. You can do this with AppLoad.
Once the LISP is loaded, run it with the COT command. Just accept the defaults. (I got an error at the end indicating a bad argument type, but it didn't seem to affect the results.)
The text and lines should now be a Table object.
Select the Table, right-click, and select "Export".
Change the "Files of type" to "Comma delimited (*.csv)", browse to a folder, and give the file a name.
Now you have a CSV file that you can open in Excel.
Please need detail information autocad to excel file.
Dear Sir,
I already attach the auto-cad drawing.Please make it excel file and send to me. I follow your instruction but this auto cad file can't open in excel file.
thanks with regards
Selim
SIR I HAVE AUTOCAD LINE TABLE I WANT RO COPY PASTE IN EXCEL BUT I COPY PASTE IT . IT IS COMING IN IMAGE HOW I CAN COPY PASTE IN EXCEL BY TEXT
how you convert the simple hand made table in to autocad table.
pleas teach me i want learnt it.
Dear Sir,
It has been 4 years since the first post. I do not remember if I had followed the steps. If you have the similar problem, you may follow the steps to check whether it's going to solve the problem or not. Just give it a try.
Regards
use attached LSP file for easiest method to convert any table to excel format (text and line)
explode the table before using the lsp command
upload the LSP file using AP command then you can put converting command TE select all table (text and line) it will convert automatically to excel then save the file.
can you please share the steps you took to convert a line and text table to convert to excel file?
