AutoCAD Express Tools
ABS 2007
170 Views, 2 Replies
04-26-2007 08:21 AM
Hi
i had problem with my buidling systems 2007, so i had to reinstall it, after
reinstallation done, my express tool is missing, of course the next course
of action is to go to add/remove program, try to chnage/modify ABS 2007, &
then select express tool, on your option window to install it again, but in
my case it says that express has already been installed, & there is a folder
under ABS2007 for express, i tried to do a search for acetmain.cui or mnu, i
found it, by using menuload command i loaded it, but it does not do any
thing, by looking at the file size & comparing to the other cui, this is
only 1 kb, meaning this is a blank file.
so how can i get my express tool back?
Matt
Re: ABS 2007
04-27-2007 09:04 AM in reply to: *Matt
Finally, i got my tool bars back & they are working fine, but icons are
missing, express folder is in my support path, any suggestions?
"Matt" wrote in message
news:5565450@discussion.autodesk.com...
Hi
Matt
New Member
0 Kudos
Post 3 of 3
Re: ABS 2007
06-02-2007 05:21 PM in reply to: *Matt
I have noticed that most of the items that were in express tools are now part of 2007 menu. It is under pulldown Format/Layers.
Hope this helps.
