AutoCAD Forum
Moving between versions
3 REPLIES 3
tim8903
212 Views, 3 Replies
Is it possible to move drawings from AutoCAD 12 to 13 and vice versa?
3 REPLIES 3
sonppw
in reply to: tim8903
If your drawing format version lower than 2013, You can use it in the both 2012 and 2013.
ennujozlagam
yes can be done vice versa and in options you can saveas your drawings that can be opened in lower version. thanks
imadHabash
you can deal with dwg files depending on file format that you use. each AutoCAD-based product uses a specific file format when saving to a file, which is important when sharing files. The following table outlines which file format should be used when sharing files with other users of AutoCAD or AutoCAD-based products:
File Format AutoCAD Release
AutoCAD 2018 AutoCAD 2018
AutoCAD 2013 AutoCAD 2013 - AutoCAD 2017
AutoCAD 2010 AutoCAD 2010 - AutoCAD 2012
AutoCAD 2007 AutoCAD 2007 - AutoCAD 2009
AutoCAD 2004 AutoCAD 2004 - AutoCAD 2006
AutoCAD 2000 AutoCAD 2000 - AutoCAD 2002
AutoCAD R14 AutoCAD R14
AutoCAD R12 DXF AutoCAD R12
”Boost
