yes can be done vice versa and in options you can saveas your drawings that can be opened in lower version. thanks
you can deal with dwg files depending on file format that you use. each AutoCAD-based product uses a specific file format when saving to a file, which is important when sharing files. The following table outlines which file format should be used when sharing files with other users of AutoCAD or AutoCAD-based products:
File Format | AutoCAD Release |
AutoCAD 2018 | AutoCAD 2018 |
AutoCAD 2013 | AutoCAD 2013 - AutoCAD 2017 |
AutoCAD 2010 | AutoCAD 2010 - AutoCAD 2012 |
AutoCAD 2007 | AutoCAD 2007 - AutoCAD 2009 |
AutoCAD 2004 | AutoCAD 2004 - AutoCAD 2006 |
AutoCAD 2000 | AutoCAD 2000 - AutoCAD 2002 |
AutoCAD R14 | AutoCAD R14 |
AutoCAD R12 DXF | AutoCAD R12 |
