Hola,
Tengo un portátil MSI ge60: i7-4700mq, 8 gb RAM, Nvidia GF GTX 760M.
Acabo de instalar AutoCad 2014 64bits y en el log del Tune log me salé unicamente la tarjeta integrada que tengo (Intel 4600) y por lo visto no me reconoce la GTX. Tengo todos los drivers actualizados de la Nvidia. Puede ser que no me la detecte por que no está cerficada o tengo que hacer algo de manera manual?
Os dejo el Tune Log.
Gracias de antemano y un saludo.
Performance Tuner Results Log
Version: 19.1.0.02
Date of Last Tune:
Machine Configuration
Processor Speed : 2.4 GHz
RAM : 8112 MB
3D Device
Name : Intel(R) HD Graphics 4600
Manufacturer : Intel(R)
Chip set : HD Graphics 4600
Memory : 1792 MB
Driver : 10.18.0010.3316
Your machine contains a 3D Device that is not certified.
As more graphics cards and 3D display drivers are tested, they are added to a list on the Autodesk website.
You can check for updates and download the latest certification list at any time. Run the 3DCONFIG command and click the Check for Updates button.
Current application driver: acaddm11.hdi
Current Effect Status:
Enhanced 3D Performance: Available and on
Smooth display: Available and off
Gooch shader: Available and using hardware
Per-pixel lighting: Available and on
Full-shadow display: Available and on
Texture compression: Available and off
Advanced material effects: Available and on
Available application drivers and effect support:
Software driver
Effect support:
Enhanced 3D Performance: Not applicable
Smooth display: Not applicable
Gooch shader: Software emulation only
Per-pixel lighting: Not applicable
Full-shadow display: Not applicable
Texture compression: Not applicable
Advanced material effects: Not applicable
Autodesk driver: Not Certified
Effect support:
¡Resuelto! Ir a solución.
Resuelto por arturopolanco. Ir a solución.
Resuelto por ReySantos. Ir a solución.
Hola, yo tengo el mismo problema con una alienware con nvida gtx 970m de 3gb y me sigue apareciendo la tarjeta intel en tunerlog,llegaste a solucionar el problema? ., gracias
Saludos. Bienvenidos al foro.
Generalmente, las computadoras vienen configuradas para utilizar la tarjeta integrada por defecto, y los programas para funcionar asumen la tarjeta gráfica primaria. Para cambiar la configuración deben ingresar a las rutinas de arranque (BIO) del equipo. Cada fabricante especifica como ingresar, lo más común es presionar alguna tecla o combinación de teclas inmediatamente después de encender la computadora. Verificar con:
F2
F10
CTRL+ALT+DEL
Dentro de la BIO buscar la configuración que se muestra en la siguientes imágenes y establecer la opción PCIE como gráfica predeterminada:
Espero les sea de utilidad.
Éxito.
P.D.
Cada imagen corresponde a diferentes tipos de interfaz de la BIO. Si no están seguros de realizar el procedimiento por ustedes mismos, les recomiendo contactar a un técnico para que realice la configuración.
Rey Santos
Exactamente lo que explica @ReySantos indica este enlace de consulta de Autodesk:
