Show only
Search instead for
When you select the Wire Numbers option, it should default to "Tag new/unnumbered only" rather than "Tag/Retag All". This would avoid the user of inadvertently retagging their wire numbers where they have chosen not to fix them.
I would prefer that the software just remember the last setting as a default. Many customers, especially those doing ladder diagrams, just click and renumber at will, since wire numbers are often based upon rung number and the wire number doesn't change anyway, unless the circuit has been modified. And if the circuit has been modified the wire number should change.
While on the subject of remembering last settings, it would be nice if the Schematic List sort order would default to the last sort settings, but I know that should be a separate idea.
