Show only
Search instead for
Thank you for your idea. We have added your suggestion to our review bucket. We encourage you to post more ideas and dont forget to give kudos to other ideas that you support.
Got ACADE 2020 a couple of days ago. I still don't think it sorts on Tags. Trouble is that Component and BOM aren't the same and if you export to Excel, where sorting can be done, subassemblies all disappear up to the top cos they don't have tag numbers. Would be nice to have this feature.
Hi, What about sorting tags within BOM's as this appear not possible to change - I have some meters on the list and the order is M1, M11, M12, M13, M2, M3 etc, is there possible to have M1, M2, M3, M4 etc?? Thank for help in advance.
Is there any way to add to the Primary Sort (or any others) that are not in the drop down? I would like to Primary sort by SH (Sheet) in the 1st step. I do NOT want tyo sort by SHeet after the Excel BOM is generated.
Yes you're right. It's just Eplan has made it so you can customize any report similar to how Autocad Electrical blocks work. Then you can have as many of each of the reports because it is done by name, not by type of report. Like currently you can only have 1 type of a BOM Project wide updatable report. It makes it hard to automate processes when limited like that.
