been using that other cad package over the weekend and again and it has a really good feature
basically it has a window that runs along the bottom of the screen this is the project database but only showing details of all the symbols on the current open page
its fully editable so you can go into fields and edit tags /part numbers /pin numbers etc etc in this case its a live update and updates the page instantly
for acade because its not linked that way to the database a button would be required in a similar function to update title block
why was i impressed with this feature i could see all the part numbers on the page and i could edit symbols fast with out popping into and out of symbols using symbol edit and it was a snap shot of the project database
i could estimate i was working at least 2-300% than if i did not have this feature
so simply putting it is it possible to have a window at the bottom of the screen which is displaying the scratch database which was fully editable and updates the drawing when finished editing ?
