As far as I know there is maybe one function (Tool) in ACADE2015 to 'generate' an Interconnection Diagram that allows you to easely create an Interconnection Diagram for Connectors via a spreadsheet.
The down side is it only works for and between connectors and splices. You can't, for example, see connections from a connector to a terminal, or between terminals.
I would like to see a tool/function wich allows me to generate/create a graphical representation of connections between terminals and between different equipment and enclosures wich are part of the same ACE project.
For example a function that allows a duplicate generation of the terminal panel layout by the terminal strip generator for all equipment/ enclosures inside the project. Which then can be connected by Wires/Cables. (By using special terminal block representations) The Information/data from, or for the creation of, this diagram could come from, or provide data for, the 'cable/ Wire from-to' reports.
Most of the data for an Interconection diagram is already available from the schematics, it would be nice if this data could be easely used to create these drawings.
