well todays improvement is when you use the block swap facility
I have had an issue this morning where i have updated a project and some of the blocks did not appear to update tthe issue was a two different symbols which looked exatly the same were used 1 updated and the other did not
in my case it was a plug/socket
this meant i had to manually go back and check the plugs and sockets and change them to be more consistent through the project (it was a good thing )
so that had me thinking about the whole block swap facility
a number of ideas immediately came to the surface
1) When doing page/project block swap ACADE should generate a report of what was changed project page/path and symbol name
2) When doing a library swap the report should include symbols not swapped as well
3) When doing a library swap maybe an option for the user to decide whether to swap an individual block in a drawing so ACADE Highlights the block it intends to swap and then asks you whether to swap the block in this instance
Block Name Display function
Also another feature would be to display the block name by pressing a button the block name appears next to all symbols so you can visually check what blocks were being used
this is to be displayed until another button is pressed to hide the block name i know i would use this type of funtion
small changes make a BIG difference
