Balloon update
Balloon update
This idea is based on a post in the discussion forum
http://forums.autodesk.com/t5/autocad-electrical-general/panel-balloon-auto-update/td-p/4325677
Need a way to update all balloons without having to re-insert each one. Updates could include:
1. balloon and text size
2. balloon type\shape
Would be nice to be able to select which balloons, do active drawing, or pick drawings from project.
8 Comments
mathalekar
It is often seen that with the change in item number or may not be desirable to keep the balloon, user need to delete them manually. Introduce the idea of balloon processing capability in the "Project tool" like it is there for "Wire Number" processing.
Add capability to delete the balloon will also help to great deal if user wants to refresh them
mathalekar
Status changed to: Gathering Support
This would be very useful as a permanent feature.
mathalekar
Thanks Pat for the suggestion. We shall evaluate your suggestion for our coming releases.
AutoCAD Electrical UX Team
t_chaws
Thank you for your idea, seems like this idea is similar to: http://forums.autodesk.com/t5/autocad-electrical-ideastation/balloon-update/idi-p/5423884
We will be tracking this idea via the above mentioned link!
Keep posting new ideas!
Best Regards,
AutoCAD Electrical Team
t_chaws
Status changed to: Accepted
suhas_kashyap
We are pleased to inform you that this idea has been implemented as a part of AutoCAD Electrical 2016 Subscription Advantage Pack 2 available to all subscription based users!
We thank you for your support!
Keep posting new ideas and dont forget to promote other valuable ideas!
Best Regards,
”Boost
