Automate Circuit Builder similar to the Spreadsheet to PLC feature.
Being able to insert circuits using Circuit Builder but using the Spreadsheet to PLC generator or something similar. The spreadsheet defines which circuits, (Circuit Builder builds them), how much space they take up, etc. everything needed to draw the drawings like the PLC generator.
9 Comments
dsnodgrass
Or at least document the correct use of "c:ace_cb_insert" with the "history" option, so that we can implement an automation app of our own. http://forums.autodesk.com/t5/AutoCAD-Electrical-General/quot-history-name-quot-parameter-in-c-ace-c...
ccad2509
looked at circiut builder its a total mess of an application see my comments here
http://forums.autodesk.com/t5/AutoCAD-Electrical-General/Automating-the-Design-Process/td-p/5166921
vikas.vaishnav
Great Idea, thank you for your suggestion. We shall look in to the request and add it to our enhancement list.
Thanks and Regards,
Vikas Vaishnav
AutoCAD Electrical Product Team.
WoHo
The following idea is very similar: http://forums.autodesk.com/t5/AutoCAD-Electrical-IdeaStation/ANSI-ISA-S5-4/idi-p/5197651
A as general as possible circuit generator, based on Excel, would be maybe a nice idea. Every customer has different raw data, e.g. data from loop diagrams, etc.; a general approach helps everyone; but must be easy to handle and nevertheless powerful ...
ccad2509
Woho
I think your missing the most important point regarding loop generation which is
for this to be successful a method of mapping a users spreadsheet to pre defined markers in a template drawings needs to be developed
Which means the end user will not want to use a spreadsheet format whcih ACADE may develope that is different from what they are currently using
ACADE must bend to what the customer does not vice versa or it will be a waste of time
t_chaws
Status changed to: Accepted
miles.nicholson
We've actually created a project builder command that plugs into AutoCAD Electrical and is driven from excel. Even RS Wire used to have a module for this
saifulbat2020
Community Visitor
PLC stands for “Programmable Logic Controller”. A PLC is a computer specially designed to operate reliably under harsh industrial environments – such as extreme temperatures, wet, dry, and/or dusty conditions. PLCs are used to automate industrial processes such as a manufacturing plant’s assembly line, an ore processing plant, or a wastewater treatment plant.
Status changed to: Gathering Support
”Boost
