Show only
Search instead for
When inserting panel footprints from the schematic list and choosing multiple devices of a different type and therefore size, AutoCAD Electrical should auto space the devices so that they are placed adjacent to one another
I agree that the new feature should also allow the user to specify a gap and this would be useful when placing fuses where finger spacing between the components is required or where an air gap between components is required.
Therefore we need three additional columns for width, length and hight; and additionals columns for the gap/distance to the surrounding components.
With these numeric data it would be also possible that AutoCAD Electrical creates the footprint automatically/on the fly; sometimes a rectangle or box for a footprint is sufficient.
Its not quite the same as the post you mentioned as I would like to see height,width and depth for the geometry. The din rail and trunking facilities would need to be changed to suit and I would recommend a dynamic block for these.
