I am running Autocad Electrical 2015 and sometimes when I double click to do zoom to extents it turns the cursor to a square and the erase command is started. I have to push escape to get out of the erase command then double click again and it will zoom to extents. This does not happen every time but it happens a lot though. We are having this issue on 4 different computers. Does anybody else have this problem?
Thank you.
Are you using the built-in double-click the mouse wheel, or have you created your own version via CUI?
Seems like the "E" in "Extents" is interpreted as "Erase" instead...
We are using the "built in" double click. We have not modified the CUI for this command.
Could it be that you, sometimes, roll the mouse wheel a little bit as you double click it? Could this be it? Seem like the '.ZOOM command is beeing canceled before it get to send the "._E" for extents.
Are you using logitech or MS-mouses?
We are using logitech mice on all 4 stations. It just seems weird because we do not have this problem if we are running Electrical 2014.
