AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Zipping a project - Downwards compatibility
5 REPLIES 5
CAD-ICE
506 Views, 5 Replies
Hi there,
I have a college that needs a copy of my project which is made in ACADE2013. My college is working with ACADE2012 so my question is if I can in a simple manner zip my project such that he can work with it in ACADE2012.
Any comments appreciated.
Regards, Gary
5 REPLIES 5
testsubject
in reply to: CAD-ICE
Gary,
Couple of things...
As long as you are not using the new sub-folder structure in the project it should be okay.
Make sure that you SaveAs all the DWGs as 2010 or Older. With ACE 2013 there is a new file saveas format.
That is what jumps to mind.
Bob Hanrahan
Ace User since 1998
If this answered your question, please click on "Accept Solution"
CAD-ICE
in reply to: testsubject
Hi Bob and thank´s for the tip.
So what you are saying is that I need to open all dwg´s in my project and save them as 2010 before I zip the project right?
I was kind of hoping that there was a shortcut in ACADE that takes care of this automatically Smiley Happy
Thanks again, Regards, Gary
acade2012
Might want to check for a LISP routine that would open them and save as 2010.
testsubject
in reply to: acade2012
Just create an scr file with QSAVE in it and then run it from the project utilities for the whole project. Be sure to change your SaveAs Setting under AutoCAD Options to 2010 first.
Bob Hanrahan
Ace User since 1998
testsubject
I discovered an even easier way to do this but it requires installing DWG True View ( the latest version is available here http://usa.autodesk.com/adsk/servlet/pc/item?siteID=123112&id=9078813 )
Here is a blogpost detailing how to do this. Pretty clever!
http://myacade.blogspot.in/2012_06_01_archive.html
Bob Hanrahan
Ace User since 1998
”Boost
