Hallo
Hope somebody can assist, I tried everything but this seems to be a issue I cannot solve.
I normally use the Ladder for reference as per picture below, all works well and size of text is correct.
Picture below. But for some reason the text when using XY is so large I cannot use it.. I probably can manual go and change all the text but surely there is something I'm missing? (Didn't change any of the defaults using IEC libraries if this makes any difference, only problem is that if I use the panel_mm library there is a problem, so currently I'm just scaling the footprint 25.4 so all work fine.. (Not sure if this got anything to do with the ladder and XY references..
Solved by labjac. Go to Solution.
I never use this functionality myself, as we always have the XY reference system as a part of the frame.
However.. It seems like this funtion use the current text style, and height to inbsert these texts.
Use the STYLE command toset the text style you want. Then use the TEXTSIZE command to set the height you want.
Try to insert the reference system again.
Hallo
Sorry for the late reply.
Can you explain how you do your reference then, will it make more sense to use the sheet number with a fixed Grid or how is your core numbering working?
I got a issue with the Autocad DB now, will start another thread, so I cannot use Autocad currently...
