Hello.
i need your help
I have been working with xy grid.
but when I create another sheet and return to the previous to place another component. the reference component is referenced to above. attached pictures of what happens. the same happens when I use an arrow of destination or origin.
please help.
thanks.
Solved by Icemanau. Go to Solution.
Have you setup the XREF display to show the sheet number?
Go to Project settings, and click on the Cross Reference tab.
Place %S in the position you want the sheet number to appear.
Save the settings
Right click on the first dwg name in the project manager.
Select Properties from the flyout menu.
Now select either Setings Compare or Apply Project Defaults.
Repeat the previous 3 steps for the other dwgs in the project until all dwgs have the same settings.
NOTE that you will need to have the Sheet box filled in on all the dwg properties for anything to show up.
This will NOT WORK if you use multiple paperspace sheets. ACADE is not set up to utilise them.
Each sheet in a dwg needs to be it's own seperate dwg.
Regards Brad
Brad Coleman, Electrical Draftsman
Let me see if I understood.
i have to create one drawing per each drawing that i need. ok.
not work like it reference numbers, where i can use multiple paperspace sheets. ok
let me do what you say. and separate the drawings ,because i have all in a multiple paperspace sheets
really appreciate your help.
thank you for you support.
