XData is Extended Entity Data. It is mostly for AcadE's own use but can be edited by the user using the XData Editor.
The stretch wire command works with one wire at a time. It is an intelligent command. You click on the Stretch Wire icon and then the select near the end of the wire you wish to stretch. AcadE will connect the wire to a nearby component that has a wire connection inline with the wire. To stretch more than one wire just use the AutoCAD Stretch command.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in
AutoCAD Electrical training and implementation support
Phone and
Web-based Support Plans AvailablePhone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please
Accept as Solution if I helped you.
Likes are also much appreciated.
