I have been getting a dot in front of x-refs for contacts that dont have pin numbers (see attached).
I am using 2014 but didnt have this problem with 2012. Is there a setting that I have overlooked that might be causing this?
Thanks.
I haven't seen this before, and I'm not able to reproduce it here.
Can you put together a single drawing sheet with this problem, and post it here?
Drawing file attached.
I just did a bit of testing and the problem only occurs when the auxiliary contact has a double digit pin number for the first pin.
Thanks.
I can now reproduce this one, and you are right. Whenever one of the other contacts has more than two digits in it's pin number, the "empty" pins are padded with a period.
Seems like a bug to me.
This dot was originally added to keep the text for each child component in line when there are no pin values on a component. This has actually worked this way for quite some time. I don't see any way to tell AutoCAD Electrical not to add this dot besides adding a pin value to the child components.
I will log this as an issue.
Sorry for the inconvenience.
Pat Murnen
