AutoCAD Electrical General Discussion
Valued Contributor
0 Kudos
Post 1 of 4
Wish List
90 Views, 3 Replies
11-21-2003 02:22 AM
1. The option for wire #s & copies not to move
unless the wire they are directly above moves.
2. A cable parent that is not a conductor, but
which contains the info for the conductors in
it, an easier way to handle Profibus cables etc.
3. Either CAT and MFG on the same layer, or a
way to to show and hide on dwg.
4. Main Report Builder - More customization, add buttons
for created reports and report formats, can merge/concatinate fields of choice, ratings/descriptions on reports other than BOM
5. A rating/field dedicated to LOAD.
6. Subassembly catalog items listed/editable from
the Main assembly component. Subassembly items not
unique to assembly - ie I can use the same connector
on many cables without duplicating the connection
catalog entry to give it an unique assembly list name.
*krollenhagen
Post 2 of 4
Re: Wish List
11-25-2003 05:07 AM in reply to: Lint
Add to wish list the ability to select with window
to the wire cutter utility, much like erase works.
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
1.
BOM
on many cables
assembly list name.
Valued Contributor
0 Kudos
Post 3 of 4
Re:
11-25-2003 11:52 PM in reply to: Lint
Another nice thing would be to be able to
see a "thumbnail" of all the drawings in a
project and be able to open them from there.
Active Member
0 Kudos
Post 4 of 4
Re:
01-12-2005 07:21 AM in reply to: Lint
Maybe what you'd like is already there. When you click on view the highlighted drawing in a project opens as a thumbnail and you can then open the drawing frome there. Not sure if that is what you were asking for or not.
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Manufacturing Community
