AutoCAD Electrical Forum
Welcome to Autodeskā€™s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Showing results forĀ
Did you mean:Ā
WISH - Automatic Reports
3 REPLIES 3
vladop
375 Views, 3 Replies
HI,
in Automatic Reports I'd like to have option NOT TO SPLIT TABLE ON ASSEMBLY ITEMS,
so that all parts of the assembly are kept together in the same section.
For example, it is defined that that each section have 35 rows, and 35th and 36th elements are relay and its base (base as subassembly) then both relay and base would be moved to next section. So, first section would have 34 rows not 35.
Vladimir
3 REPLIES 3
in reply to: vladop
Hi Valdmir,
If you are part of the ACADE beta program, I would suggest logging this as a Feature Request.
If you are not part of the beta testing let me know and I will log the Feature request for you.
James Alger
SolidCAD
vladop
No, I'm not.
Thank you.
Vladimir
in reply to: vladop
Hi Valdimir,
I can't discuss the beta on the Forum, other than to say:
I have posted the feature request.
James Alger
SolidCAD
ā€Boost
