AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Wires, Wire numbering, and Scooting
8 REPLIES 8
Message 1 of 9
testsubject
380 Views, 8 Replies
Nate,
Has there been any changes to address putting wires on a wirelayer that does not update with wire numbers? I am presently putting all wires that I do not want to have a wire number on layer 0 (zero), but if i was to scoot a component on that wire, the wire located on layer ) is not included and I have to manually re-attach it. I know we talked about this once before and was wondering if it was addressed in AE or not yet. I am still working off of R16.1 but hopefully I will be getting AE 2004 by the end of next week. It is kind of a pain to have to reconnect a bunch of wires to terminals after doing an Align.
Robert Hanrahan
Bob Hanrahan
Ace User since 1998
If this answered your question, please click on "Accept Solution"
8 REPLIES 8
Message 2 of 9
testsubject
in reply to: testsubject
Bump
Bob Hanrahan
Ace User since 1998
Message 3 of 9
testsubject
Bump again
Bob Hanrahan
Ace User since 1998
Message 4 of 9
Try putting the wire on the _MULTI_WIRE layer. I think that does what you want. John Pullen "testsubject" wrote in message news:19817409.1081354775048.JavaMail.jive@jiveforum1.autodesk.com... > Nate, > > Has there been any changes to address putting wires on a wirelayer that does not update with wire numbers? I am presently putting all wires that I do not want to have a wire number on layer 0 (zero), but if i was to scoot a component on that wire, the wire located on layer ) is not included and I have to manually re-attach it. I know we talked about this once before and was wondering if it was addressed in AE or not yet. I am still working off of R16.1 but hopefully I will be getting AE 2004 by the end of next week. It is kind of a pain to have to reconnect a bunch of wires to terminals after doing an Align. > > Thanks, > > Robert Hanrahan
Message 5 of 9
testsubject
John,
That did not work. If it is in the Wire Layer list I can scoot and it will assign a wire number. If it is not in the wire Layer List then it will not scoot.
Thanks anyway
Robert Hanrahan
Bob Hanrahan
Ace User since 1998
Message 6 of 9
In testing this a bit more, it works fine doing that if the non-wire layer line is on the right side of a component, not if on the left. Very strange. "testsubject" wrote in message news:31579760.1082479882616.JavaMail.jive@jiveforum1.autodesk.com... > John, > > That did not work. If it is in the Wire Layer list I can scoot and it will assign a wire number. If it is not in the wire Layer List then it will not scoot. > > Thanks anyway > > Robert Hanrahan
Message 7 of 9
testsubject
Bumping back to the top again...
(beginning to think Autodesk is mad at me...)
Bob Hanrahan
Ace User since 1998
Message 8 of 9
Yes, it makes sense that if the INSERT COMPONENT works just fine when inserting a device into a LINE entity that is not on a wire layer, then the ALIGN COMPONENT and the SCOOT commands should also keep the lines reconnected when these commands reposition the inserted component. I'll submit this as a defect. "testsubject" wrote in message news:19817409.1081354775048.JavaMail.jive@jiveforum1.autodesk.com... > Nate, > > Has there been any changes to address putting wires on a wirelayer that does not update with wire numbers? I am presently putting all wires that I do not want to have a wire number on layer 0 (zero), but if i was to scoot a component on that wire, the wire located on layer ) is not included and I have to manually re-attach it. I know we talked about this once before and was wondering if it was addressed in AE or not yet. I am still working off of R16.1 but hopefully I will be getting AE 2004 by the end of next week. It is kind of a pain to have to reconnect a bunch of wires to terminals after doing an Align. > > Thanks, > > Robert Hanrahan
Message 9 of 9
testsubject
Thanks for the info, Nate.
I just finished downloading the latest beta and am looking forward to seeing all the new stuff.
Bob Hanrahan
Bob Hanrahan
Ace User since 1998
”Boost
