Yes, it makes sense that if the INSERT COMPONENT works just fine when
inserting a device into a LINE entity that is not on a wire layer, then the
ALIGN COMPONENT and the SCOOT commands should also keep the lines
reconnected when these commands reposition the inserted component. I'll
submit this as a defect.
"testsubject" wrote in message
news:19817409.1081354775048.JavaMail.jive@jiveforum1.autodesk.com...
> Nate,
> Has there been any changes to address putting wires on a wirelayer that
does not update with wire numbers? I am presently putting all wires that I
do not want to have a wire number on layer 0 (zero), but if i was to scoot a
component on that wire, the wire located on layer ) is not included and I
have to manually re-attach it. I know we talked about this once before and
was wondering if it was addressed in AE or not yet. I am still working off
of R16.1 but hopefully I will be getting AE 2004 by the end of next week. It
is kind of a pain to have to reconnect a bunch of wires to terminals after
doing an Align.
> Thanks,
> Robert Hanrahan
