Layer colors are set using the Layer Properties Manager. I advise creating
a template with all your layer colors preset.
It looks to me like your wires are a but close together. The default text
is 0.125 if you are inserting from the JIC125 library folder. There is a
JIC1 folder as well, for 0.1 text. But under Project-wide Utilities you can
change the font type and size and apply project-wide to components that are
already inserted.
If you want to permanently change the text size in the blocks themselves,
use the Modify Symbol Library tool. It will take a couple of hours to go
through an entire library folder and change all the attribute text sizes.
There are many, many symbols in each folder. I suggest copying the folder
and renaming the copy before modifying. For example, if you are changing
the JIC1 text size from 0.1 to 0.75, consider copying JIC1 and naming it
JIC075. Then run the symbol library modification routine. Be sure to
switch your project properties to point to the new library.
If you only want to modify the text size for the source and destination
arrows, just modify the individual blocks in whichever symbol library you
are pointing to with your project properties. You can double-click a symbol
to find out the block name (i.e. file name less the .DWG).
wrote in message news:5905223@discussion.autodesk.com...
It works but is a bit cumbersome. It relabels the wire number and the
attribute block it puts at the end is too big.
See attachment.
How do I change the text style of all these attributes?
How 'bout layer colors?
I can update these things after they're inserted but I'd like to not have to
do that!
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in
AutoCAD Electrical training and implementation support
Phone and
Web-based Support Plans AvailablePhone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please
Accept as Solution if I helped you.
Likes are also much appreciated.
