AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Wires between the terminals of one component
6 REPLIES 6
galashkina
514 Views, 6 Replies
Can I connect the wires to the terminals of one component, so that the wire is displayed in the report?
6 REPLIES 6
rhesusminus
in reply to: galashkina
Can you post the DWG?
Then I could have a look...
Trond Hasse Lie
AutoCAD Electrical and EPLAN expert
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
galashkina
Something with my symbol is not so. Checked on the other - works.
rhesusminus
I'm not sure WHY, but if you draw like this, it works (i.e. You must use multiple wires to connect)
Maybe someone from Autodesk can explain why?
Trond Hasse Lie
Ctrl Alt El
galashkina
in reply to: rhesusminus
These wires are included in the report? I do not.
If you insert the cable core, they will turn into the report.
rhesusminus
Yes:
Trond Hasse Lie
Ctrl Alt El
galashkina
rhesusminus, thank you! You helped me again.
If the connection is to create not one, but several segments arranged in a single line, the report turns out right.
”Boost
